Pipes, Boost & Juice Talk about Exhaust, Nitrous, Blowers, Turbos, Superchargers... whatever makes you go faster!
window switch
Old Mar 19, 2007 | 01:11 AM
hitsman10's Avatar
hitsman10
Default window switch
im wiring my window switch right now and need to know were the tach terminal or coil connection is??
Old Mar 19, 2007 | 08:05 PM
nitrous_bob's Avatar
nitrous_bob
Default RE: window switch
tach terminal = tach pickup = would be the spade on a msd box
otherwise it's one of the wires on the coil itself. i wanna say the red/green but not certain.
do you have an old shift lite or a tach ? touch it to it, and you'll see, but i am about 99% certian it's the red/green, it's the positive side of it anyways.
BUT !!!! if you have an msd , and are using the tfi connector harness, you have to wire it to the new harness, NOT the coil. you won't break anything, but it won't work, you have to wire where the harness jumps into the old wiring.
Old Mar 19, 2007 | 08:06 PM
nitrous_bob
nevermind , you have an '03 , i have no idea what colors are in there.
Old Mar 19, 2007 | 10:40 PM
GT 281's Avatar
GT 281
Pull your harness plug ( the big one behind the passanger side strut tower) apart 1 10mm and it seperates. Its the top right wire if your looking from the front to the back. I want to say its # 26-or 46 something like that.
cr620
Oct 3, 2022 10:18 PM
lincolnshibuya
Jul 5, 2020 03:05 AM
PaulH2
20
Jan 31, 2016 09:48 AM
guitarman376
Sep 30, 2015 05:54 PM
DreadPirateRoberts
Sep 26, 2015 02:11 PM
