Pipes, Boost & Juice Talk about Exhaust, Nitrous, Blowers, Turbos, Superchargers... whatever makes you go faster!
single turbo question
Old Mar 21, 2007 | 12:43 AM
Emanpimpster's Avatar
Emanpimpster
Default single turbo question
Is it absolutely necesarry to merge both sides of exhaust to run to a single turbo? Why couldnt you just use one side? Would it just have longer lag times?Like one side just be regular and the other lead to a turbo.
Old Mar 21, 2007 | 03:19 PM
pbguns's Avatar
pbguns
Default RE: single turbo question
because you need and even flow of back pressure if one is running off the engines exaust and one is coming from the turbo i wont run right
Old Mar 21, 2007 | 05:20 PM
luckythirteen13's Avatar
luckythirteen13
one reason is that the turbo will have rediculous lag since only half the motor is feeding the exhaust side of the turbo. the second reason is because of differences it back pressure in the exhaust. you need to run the exhaust from both sides of the motor into the turbo
Old Mar 22, 2007 | 01:04 AM
FoxGT's Avatar
FoxGT
Won't work. Either Saab or Volvo tried it a long time ago.
treesloth
Sep 28, 2015 07:03 AM
2015Ecoboost
Sep 17, 2015 01:48 PM
Daddys Girls GTs
Sep 14, 2015 08:46 PM
jaiidutch
Sep 14, 2015 10:29 AM
