Pipes, Boost & Juice Talk about Exhaust, Nitrous, Blowers, Turbos, Superchargers... whatever makes you go faster!
holset identification help
Old Mar 13, 2007 | 11:47 PM
Chemical_Excuse's Avatar
Chemical_Excuse
Default holset identification help
i have a big holset on my car...(came on it when i bought it)...but i don't see an id tag or serial #...just says holset big on the intake side of the turbo
Old Mar 14, 2007 | 06:29 PM
FoxGT's Avatar
FoxGT
Default RE: holset identification help
Better off asking in 4 cylinder section, lots of people upgrade their turbos to the holset
Old Mar 16, 2007 | 06:28 AM
Chitown racer's Avatar
Chitown racer
The most common one used is off of the Dodge truck that came with the 5.9 cummins diesel. I believe the holset model numbers were HX35W and HY35W. Not sure on the housing or turbine specs though. I have heard that people using them in a single turbo setup on a 5.0 engine can only get around 12 psi max out of them. After that the turbo is pretty much done.
Old Mar 16, 2007 | 08:24 PM
Chemical_Excuse
i've hit 20 psi several times and this thing screams, turbo seems fine...just wanted to know a way to tell the difference...the only numbers i see are on it's wastegate
Old Mar 18, 2007 | 04:45 PM
FoxGT's Avatar
FoxGT
They're probably one of the toughest turbos they put on stock vehicles out there. More than likely it's an hx35. Do you have any pictures?
Old Mar 18, 2007 | 06:29 PM
Chemical_Excuse
it's an he351 i read the numbers on the wastegate...it's a newer version of the hy35...a little bigger compressor housing than the hy35....i'll get pics up when i can...i've only had the car a week....thanks
Old Mar 20, 2007 | 10:57 PM
Davojan59's Avatar
Davojan59
ORIGINAL: Chitown racer
12 psi sounds way too low for those turbos. They push around 25-30 psi on the Cummins diesels...
Old Mar 22, 2007 | 01:14 AM
FoxGT's Avatar
FoxGT
They're fine pushing 12, but the stock wastegate spring I believe is set at like 22 psi.
livefast1
Apr 13, 2008 12:48 AM
mstg007
Mar 20, 2008 04:51 PM
b16sir1991
Apr 26, 2007 01:23 PM
l_shizzle_l
Jan 15, 2007 09:27 PM
