Pipes, Boost & Juice Talk about Exhaust, Nitrous, Blowers, Turbos, Superchargers... whatever makes you go faster!
Fuel problem
Old Nov 19, 2004 | 05:23 AM
uvbnbitn97's Avatar
uvbnbitn97
Default Fuel problem
I have a Vortech vs-1, custom chip, adj. fuel pressure reg, stock injectors, and stock mass air. My question is when I'm at Idle the car acts as if it's loading up on fuel but then when you get on it reads as if it's running lean. I bumped up the fuel pressure but that made the idle worse and it still runs somewhat lean. Any suggestions
Old Nov 19, 2004 | 02:57 PM
Birdieman4's Avatar
Birdieman4
Default RE: Fuel problem
Check to make sure your fuel pump is working properly. Also, your injectors may be too small. How much boost you runnin? If you're running 7+ psi, your injectors are probably hurting your top end performance.
SSRFUZZY
Members Other Vehicles
Jan 6, 2016 08:22 PM
StalkerGT
Sep 25, 2015 02:41 PM
zanemoseley
Sep 6, 2015 12:58 PM
5.0 kevo
Sep 3, 2015 06:24 PM
SYNY5TER
Sep 2, 2015 01:35 AM
