Pipes, Boost & Juice Talk about Exhaust, Nitrous, Blowers, Turbos, Superchargers... whatever makes you go faster!
Supercharger help
Old 08-14-2003, 04:00 PM
Richman
Richman's Avatar
Default Supercharger help
Any help you guys could give me would be really appreciated. I have a 96' cobra and I was curious what is the biggest and best supercharger/turbocharger that I can use on the street and on that track and put up impressive numbers, this would be a daily driver and I want nothin but power, Any other suggestions would be appreciated, Thanks
Rich
Any suggestions to put me in the 11's
Richman is offline
Old 08-14-2003, 04:25 PM
horatio102
horatio102's Avatar
Nothing but power?
How about reliability? Somebody can suggest something that'll get you 1100hp, but it'll only last one run (if that).
You planning on building the bottom end? Or do you figure that you can just slap a blower on the stock stuff and have huge gains without any problems?
horatio102 is offline
Old 08-14-2003, 04:41 PM
BCisme
BCisme's Avatar
get an ATI procharger, gears full exhaust, drag radials. bam!!! 11's.<IMG src=smileys/smiley2.gif border="0">
BCisme is offline
Old 08-16-2003, 04:02 AM
stang574
stang574's Avatar
Well Vortech and Paxton both make really good kits for your cobra motor. The biggest/baddest is probably more than you want anyway. With 400-500 ponies at your command you'll be plenty pleased.
stang574 is offline
Old 08-18-2003, 10:50 PM
vfast
I ♥ Acer
vfast's Avatar
s-trim votech with a 12 pound pulley is all you need
vfast is offline
Old 10-02-2003, 08:56 PM
Gunner
Gunner's Avatar
vfast...u dont think 12 pounds is too much with a stock bottom end? i got a 92 5.0 and people are tellin me not to go above 10psi with mine</P>
Gunner is offline
Old 10-02-2003, 10:19 PM
vshayes
I ♥ Acer
vshayes's Avatar
You got factory forged pistons... as long as you keep your A/F ratio and your timing right then 12 is fine. Make sure you have a timing retard system or chip tuning to keep everything happy, whether or not you run 10 or 12. The difference though is alot prolly 30 hp + more running 12.
vshayes is offline
GimpyHSHS
19
12-19-2023 01:12 PM
Gene K
10-21-2015 11:37 PM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
col2560
09-25-2015 08:59 PM
Quick Reply: Supercharger help
