10 psi???
once i get my car tuned(by next week) would i be safe running 10 psi or should i just wait until i build the motor it has kinda high mileage but i believe most of it was highway miles.
less restriction on the inlet side of the blower. If your lookin for just 10# I'd keep the pulley on there and get a powerpipe - same boost as the pullied setup with less strain / rpm's on the blower = same boost with less heat = more power.
yea maybe ill invest in a smaller pulley after id but the aftercooler so it will transfer the heat out and just make that much more power, as you can see power pipe has been on my list for some time. but the steeda one looks nicer than the anderson one so do they perform equally as well. also the steeda is 50$ cheaper. do you have one md or did you put one on with the blower?
jwog666
Dec 27, 2021 08:09 PM
