Pipes, Boost & Juice Talk about Exhaust, Nitrous, Blowers, Turbos, Superchargers... whatever makes you go faster!
To go with a TT or a Kb for my 03 GT??
Old Dec 8, 2004 | 04:53 PM
  #21
StangGT804's Avatar
StangGT804
I ♥ Acer
Default RE: To go with a TT or a Kb for my 03 GT??
Thanks!! But hey guys I want my car to last long! So if I get a TT, my engine wont last LONG??? What! No!
Old Dec 8, 2004 | 04:58 PM
  #22
FoxGT's Avatar
FoxGT
Turbo's will be better on gas. What rpm range do you want the most power?
Old Dec 8, 2004 | 05:00 PM
  #23
StangGT804's Avatar
StangGT804
I ♥ Acer
I really dont undertand most of this rpm range stuff! What would be the best!!???
Old Dec 8, 2004 | 05:05 PM
  #24
mdvaldosta's Avatar
mdvaldosta
I ♥ Acer
Turbo's are no worse on your engine than any other poweradder, its the hp figures & tune that are hard on an engine - not how you get it
Old Dec 8, 2004 | 05:08 PM
  #25
Birdieman4's Avatar
Birdieman4
I was wondering which mod would give me the best results all around!!!
No one attempted to answer this question. All around performance? Not even close. KB, hands down. Look at the december issue of MM&FF and they do a tt vs twin screw vs centrifugal blower test. For all around performance, its not even close. The KB shines. With a KB, you don't really sacrifice anything. A little less top end, a lot more mid and bottom end. I hear a lot of people say, " screw blowers have no top end". That is a fallacy. In the same article, if you compare the Vortec to the KB. Many would think that at high rpms the vortec outshines the KB by a lot. Not true. The Vortec's hp curve (at 11psi) meets the KB hp curve at 5750 rpm. The KB beat's 'em all for all-around performance.
Old Dec 8, 2004 | 05:11 PM
  #26
StangGT804's Avatar
StangGT804
I ♥ Acer
So is it worth destroying the engine? By putting on these poweradders?
  #27
mdvaldosta's Avatar
mdvaldosta
I ♥ Acer
nothing can compare to the hp / boost levels of a properly sized tt setup - I saw that article too Birdie - but looking at real-world performace (the hundreds of cars MPH has turned out, dozens with KB's, hundreds with centrifugal's, and a couple with TT's) - at 8psi most folks with the KB kit are getting 375 or so rwhp with the KB, with the TT their getting 400+ detuned, with more torque.
Old Dec 8, 2004 | 05:15 PM
  #28
StangGT804's Avatar
StangGT804
I ♥ Acer
So if i did buy this kit and got a good tune with it, then my car would do fine???
Old Dec 8, 2004 | 05:19 PM
  #29
Birdieman4's Avatar
Birdieman4
I'm not doubting the efficiency of tt's or a centrifugal. They are more efficient than a positive displacment blower. -But he asked which is better for 'all around' performance. It's not even close. To me, the only reason you would tt's is for BIG hp, I'm talkin 600+. That is where there efficiency realy shines. Give me any good argument for tt's on stock internals. -You might as well do a centrifugal.
Old Dec 8, 2004 | 05:22 PM
  #30
StangGT804's Avatar
StangGT804
I ♥ Acer
What is centrifugal???
