Pipes, Boost & Juice Talk about Exhaust, Nitrous, Blowers, Turbos, Superchargers... whatever makes you go faster!
anderson pms
Old May 20, 2007 | 06:34 PM
kennebell92conv's Avatar
kennebell92conv
Default anderson pms
i just got my pms system for my kenne bell 5.0 do you need a starter programme and do you need a new mass air sensor i have a kenne bell 80mm mass air the system is 04 the new one
Old May 20, 2007 | 08:51 PM
luckythirteen13's Avatar
luckythirteen13
Default RE: anderson pms
if you bought the pms new, rick anderson will make you one free start up tune.
you shouldnt need a new mas, as long as its calibrated for the injectors you have.
you dont have to have a start up tune. after you hook it up, the car will start up running off the stock computer since the pms has no inputs in it.
Old May 20, 2007 | 08:59 PM
kennebell92conv
bought it from ebay its is new the guy never installed it in his car do you have the system and thanks bro
Old May 20, 2007 | 10:21 PM
luckythirteen13
yes i have the pms. if you would like to pm me your mods, boost level, fuel octane, etc, i can give you a base tune. it will be super conservative and you will need a wide band to tune it all the way but it will be a start. or you can try your luck at stangtuning.com some times they will help with base tunes and some times they wont.
Soldier GT
Aug 12, 2015 03:46 PM
SJ Stang
Aug 21, 2004 05:47 AM
Patterson
Dec 20, 2003 02:00 AM
mustang20010
Dec 10, 2003 08:33 PM
