Whats everyone's setup?
Just curious as to what blowers you guys have, what your engine/exhaust stetup is and what kind of numbers are you putting down and what times your running, if you have them..thanks
RE: Whats everyone's setup?
Built 393 stroker, Vortech Renegade YSi setup with blow through carb. Will have it on E85 for the extra cooling and 105 octane. Project is almost complete, with 750 HP for street use the target.
I start on the fuel system this week, then will add the enclosure and SC discharger tube.
K.B. 2.1 @ 6psi non i/c
Demolet cai, BBK 70 mm t/b
Mac prochamber, Mac cat-back
330 rwhp 320 rwtq
12.8 @ 109 1/4 time
8.2 1/8 mile
[IMG]local://upfiles/67774/8054086FD2184D949394E20323074D45.jpg[/IMG]
[IMG]local://upfiles/67774/CE24F65BF92D4E58B91C337CDF8AA030.jpg[/IMG]
330 rwhp 320 rwtq
12.8 @ 109 1/4 time
8.2 1/8 mile
Built MMR Street Pro 900 shortblock
Patriot stage 3 heads & blower cams
3.73 FRPP gears
MAC Long Tube headers
Mac shorty catted H pipe
SLP Loudmouth 2 catback (changing soon. way too loud with the new LTs)
75mm Accufab throttle body
MAC Plenum
Vortech v2 with 2.60" pulley (16.5psi)
60lbs ford racing fuel injectors
2003 cobra fuel tank
Dual Ford GT 255lph fuel pumps
AFM Powerpipe
Snow Performance Boost Cooler stage 2 (methanol injection) w/ safe injection kit
Full length subframe connectors
UPR upper and lower control arms
Steeda Tri-ax short throw shifter
SPEC stage 3 clutch
Nitto 555R 275 - 40 - 17 drag radials
3.73 FRPP gears
MAC Plenum
AFM Powerpipe
SPEC stage 3 clutch
ORIGINAL: nanaki
3.73 FRPP gears
MAC Plenum
AFM Powerpipe
SPEC stage 3 clutch
3.73 FRPP gears
MAC Plenum
AFM Powerpipe
SPEC stage 3 clutch
255 LPH fuel pump
40 LB ford racing injectors
C+L MAF
Vortech A trim at 8lbs
trick flow 1.7 rockers
chromoly pushrods
trick flow track heat intake
canfield 195CC heads
ARP head studs
custom ground cam from jay alan at camshaft innovations
mac shorty headers
mac prochamber
75MM accufab TB with spacer
bunch of other small things
all on the stock 70K mile shortblock
450/460
C+L MAF
chromoly pushrods
ARP head studs
mac shorty headers
mac prochamber
450/460
ORIGINAL: tdclark1984
Can we get Turbo setups and numbers as well on here as well?
fully forged 331
afr 205cc head
mild cam
twin turbo
3" exhaust
etc
etc
