Turbo setup question
would it be possible to run a turbo setup with a bunch of synched up electric exhaust cutouts, and be able to go from N/A to twins with the flip of a switch, i figure if there synched, one to reroute the air intake, and one or two to reroute the exhaust away from the turbo(s), and have the BOV open and let it/them spool down, but then flip a switch, let it/them spool up, and be able to smoke any car ever made
just wondering what you guys thought, and if this is even remotely possible
you could probably rig some way up to do that. Just like you can take the turbo off a car and then crank it and it will still run as long as your blowing through the MAF sensor and not drawing air through it, which you shouldn't do anyways.
But wouldn't it just be easier to turn the boost down though, i mean a turbo'd engine bay is crowded enough without all the cut-out valves and wiring, etc.
Luke9222
Oct 22, 2015 11:55 PM
uberstang1
Sep 20, 2015 06:42 PM
jaiidutch
Sep 14, 2015 10:29 AM
