Pipes, Boost & Juice Talk about Exhaust, Nitrous, Blowers, Turbos, Superchargers... whatever makes you go faster!
Window Switch help
Old Aug 23, 2007 | 10:13 PM
Willem_Black's Avatar
Willem_Black
Default Window Switch help
Ok, this should be my last install help question. I've officially finished everything except connecting the fuel line, but that is already run and sitting in the engine bay. Other than that everything is done. My question however is that I just finished wiring up my zex window switch. I connected it to the brownish wire on the first coil. I have the window switch sitting in my glove box so I can see it while behind the wheel. When I turned on the car, I noticed that the window switch was jumping around a lot. That is, the rpms were going from 500-ish, to 1500-ish randomly at idle. My car was idling at 700 rpms though. I think I must have set it up wrong. I doubt that it is wired wrong because I found the info on the correct wire in about a half dozen posts on another site. In the zex instructions it says:
STEP 1
: TACH signal set-up
Number display B and C should be set to the chart below (Number display A is not used in this step):
0 0
= individual coil per cylinder systems where the TACH wire is connected to the coil
0 1
= coil packs that fire in pairs (waste spark systems) and the TACH wire is connected to the coil
0 2 ~ 1 2
= number of engine cylinders, from 2 to 12, where the TACH wire is connected to the tach
from the engine electronic controller or distributor
I've got it set at 00. Is that right? If not, what should I set it at?
Old Aug 23, 2007 | 11:44 PM
Willem_Black
Default RE: Window Switch help
Never mind, I got it figured out. Forgot I had to turn the car off and then on again for changes to take effect. I'll try go through the pics I took during the install and take a couple more of the finished project and try do a write up if anyone thinks it'll be a good idea.
Old Aug 24, 2007 | 03:10 PM
nitrous_bob's Avatar
nitrous_bob
cool, cuz i have no clue lol , no help at all.
on older cars it's much much much easier
cr620
Oct 3, 2022 10:18 PM
lincolnshibuya
Jul 5, 2020 03:05 AM
PaulH2
20
Jan 31, 2016 09:48 AM
guitarman376
Sep 30, 2015 05:54 PM
DreadPirateRoberts
Sep 26, 2015 02:11 PM
