Pipes, Boost & Juice Talk about Exhaust, Nitrous, Blowers, Turbos, Superchargers... whatever makes you go faster!
window switch help
Old Sep 13, 2007 | 10:42 AM
bighungrymatt's Avatar
bighungrymatt
Default window switch help
I have a zex window switch on my 87gt, I wired it to the negative wire on my coil and set it to 08. The numbers jump around sporadically and doesnt seem to match my tach... anyone know how to fix this problem?[/align][/align]
STEP 1
: TACH signal set-up
Number display B and C should be set to the chart below (Number display A is not used in this step):
0 0
= individual coil per cylinder systems where the TACH wire is connected to the coil
0 1
= coil packs that fire in pairs (waste spark systems) and the TACH wire is connected to the coil
0 2 ~ 1 2
= number of engine cylinders, from 2 to 12, where the TACH wire is connected to the tach
from the engine electronic controller or distributor
[/align]
Old Sep 13, 2007 | 10:23 PM
bighungrymatt
Default RE: window switch help
ttt
Old Sep 13, 2007 | 10:30 PM
luckythirteen13's Avatar
luckythirteen13
you dont have an msd box do you? if so, just get your tach signal from that
Old Sep 13, 2007 | 10:35 PM
bighungrymatt
no msd box...
Old Sep 13, 2007 | 10:53 PM
bighungrymatt
I wonder if a bad ground would cause that...
cr620
Oct 3, 2022 10:18 PM
lincolnshibuya
Jul 5, 2020 03:05 AM
PaulH2
20
Jan 31, 2016 09:48 AM
guitarman376
Sep 30, 2015 05:54 PM
DreadPirateRoberts
Sep 26, 2015 02:11 PM
