Help with programming zex window switch
Can one of you Nitrous please tell me how to program the zez window switch...Their instructions are not to good. All of your help is appreciated.
[align=left] [/align]
What are you trying to do, just set up the rpm window to activate the nitrous?
If so, then when the car is on just hold the 2 buttons till it says "PRO". After that you will have to set up the tach signal....which for your car I don't know what it would be, but you can ask others with that car to see what the car has. Either it will be:
00 = individual coil per cylinder system
01 = coil packs that fire in pairs
02 ~ 12 = # of engine cylinders from 2 - 12 where tach wire is connected to tach from engine electronic controller or distributor
That's the hard part, but you can just pick any random one until it works if you can't get any answers about which is the right one. I just had to figure it out through trial and error.
After that the second option is traction control skip-shift. I have mine at 0. If you enter say 2 for instance, that is how many times your rpms must pass the upper end of the rpm window before you activate the nitrous.
Step 3 and 4 are the important ones, activation and deactivation respectively. After you enter these it should say "END"
Turn off the car, then turn it back on, the rpms should display on the led display the same as they do on your tach.
Will, thanks for your stight forward instructions....I will give it a shot...I have a FI, 302 MSD if that helps the set up?
DreadPirateRoberts
Sep 26, 2015 02:11 PM
0, 02, instructions, mustang, program, programiming, programming, reads, set, switch, switches, window, zex
