Pipes, Boost & Juice Talk about Exhaust, Nitrous, Blowers, Turbos, Superchargers... whatever makes you go faster!
nitrous problems
Old Sep 22, 2007 | 07:28 PM
nitrous_bob's Avatar
nitrous_bob
Default RE: nitrous problems
look at the fittings, check the AN fitting in and out of the nitrous selonoid(s)
paste will start to turn brownish, and accumulate dust, tape will be be bright white and obvios cuz the ends will start to fray
w/ the bottle off and car off, arm the system and engage the nitrous, listen to how loud and defined the "click" is after the selonoid opens
Old Sep 23, 2007 | 12:37 PM
stang4life05's Avatar
stang4life05
after the engine was fixedthe solenoids were unhooked and stuff to run the engine awhile before spraying it so ill have to make sure to use paste, thanks for the help guys
Old Sep 23, 2007 | 02:28 PM
stang4life05
just an update....paste was used, but as wmrcer said i think it was just a problem with the window switch not being set correctly
Old Sep 23, 2007 | 07:07 PM
contentsunderpressur's Avatar
Are you using a micro switch or a activation switch that works off the TPS?
Old Sep 23, 2007 | 11:35 PM
stang4life05
activation switch
Old Sep 24, 2007 | 04:56 AM
If it's a micro activation switch that has the little arm that the throttle hits then check it.My nitrous did the exact same thing to me one time and that switch was broken keeping it activated. I had a window switch at the time as well. When I got to the activation point of the window switch the nitrous turned on and even when I let off the gas the micro switch was still activated and it still sprayed the nitrous because the rpms wouldn't drop below the shut off point of the window switch. I had to turn the ignition off. Then I unpluged all the coils and spun the motor over for a solid min. to get all the nitrous out of the motor.
Seanam
Oct 4, 2015 10:15 AM
mdj89
Sep 23, 2015 08:49 AM
kachuy10
Sep 22, 2015 01:27 PM
stangin1996gt
Sep 21, 2015 11:01 AM
Big Al's 03
Mach 1 Section
Sep 21, 2015 07:59 AM
