Few Questions regarding P1SC
hey im not every "educated" on the whole FI thing so i have a few questions...
1. my local shop has a USED P1SC head unit for sale for a 4.6L 2V, whats a good price to offer him since hes not sure?
2. what should i look for in a USED P1SC?
3. i looked at that $1500 96-04GT Supercharger kit "how its done" post and i was wondering could i just do that exact thing except put a P1SC instead of a Vortech V-2 SQ head unit?
4. how much boost am i able to run on a stock bottom end w/ a CR of 10.5:1 ? the local shop says 8lbs..
5. whats the max boost a P1SC can make ? since i will be swapping my bottom end out so i can run higher boost.
6. how much power do you think i would make w/ 8psi P1SC w/ the following mods: PI Swap, Magnaflow Catted X, Flowmaster CB, Accufab 75mm TB/Plenum, JLT CAI, & Tune.
thanks alot for all your help [8D]
The kit is worth 3000 dollars if it's in good shape with the intercooler and all. With compression that high I would be carefull running 8 lbs of boost and wouldn't think of going any higher. The 1500 dollar kit you read about is possible because you can buy all the brackets and stuff separtate for a Vortec but not a procharger as far as I know. With compression that high I would imagine you'd put down 400 rwhp or very very close with 8 lbs of boost. The P-1 blower can turn up to about 16 lbs of boost with an 8 rib kit and very small pulley.
I'd say you can run 8lb fine as long as you don't add a whole lot of timing. You may even be able to run 10lb on even less timing but the power output would probably be similar.
On f/i cars timing is where the power is at, but with higher compression you can't add lots of boost and timing and still run pump gas..
I would say at 8psi you would make close to 400rwhp. My car made 395at 10lb with 21 degrees total timing.
There is a gu y on here with a blue pi swap making big power.. maybe someone else knows his sign in name.
I sold my P1SC recently to a local enthusiast for $2500 incl intercooler etc. He thenran a 12.2 on street tires and I think a 1.9 sixty foot, so he's definitely got him a solid11s mustang now with a little practice and some minor suspension mods. I sell all my stock parts at a verylow price. Girlfriend won't allow me to collect car parts. Sold stock tranny and already sold stock short block.Anybody need a stock rearend...lol? (last big part).
On his 2007 gt, the P1SC made 484 rwhp at 10lbs...don't know how that relates to a 2v though.
ORIGINAL: jEEd
yeah its LizzyFan, has a S-Trim w/ PI Swap . but he also has an MMR600 Short Block w/ forged internals soo yeah...
I don't think the CR will be an issue if you run 8 psi, you just need to watch the stock bottom end by getting it dyno tuned watching the A/F and keep the numbers to the rear wheels in the low 400's. The MagnaFlow Tru-X seems to produce more torque than other setups I have seen the P-1SC on. Depending on the health of everything involved and the setup, you would probably be looking at a 350-420 RWHP window. Unfortunately, there's too many variables involved to get you an exact number. My numbers are in my sig...
AMAlexLazarus
AmericanMuscle.com
Oct 2, 2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
treesloth
Sep 28, 2015 07:03 AM
