Pipes, Boost & Juice Talk about Exhaust, Nitrous, Blowers, Turbos, Superchargers... whatever makes you go faster!
pcv valve help
Old Dec 11, 2007 | 09:27 PM
txstroker's Avatar
txstroker
Default pcv valve help
My car was smoken bad at hi rpms so on the advice of some oneI capted it off now my fresh 347 stroker moter is leaking oil.I wonder how muchI mesed it up,I was going to put on a vt butI dont know ifI should know. Has this happend to some one out there? if so what seals go first when your crank case is over presherized.
Old Dec 11, 2007 | 11:17 PM
GT350Stang's Avatar
GT350Stang
Default RE: pcv valve help
I would first check compression and then go from there. I would look at the front and rear main seals then go to intake seals. IMO
Old Dec 12, 2007 | 04:15 PM
only90s's Avatar
only90s
ORIGINAL: txstroker
Plug the PCV back in...take my advice...I went through this earlier this year....plug the PCV back to vacuum and run an Oil Seperator...that will filter out the oil so you stop smoking....
Take a look at my engine....see the black thing in the left corner...that is a Husky Air Compressor Oil Seperator....I have to empty out about 3 ounces of fluid every 500-600 miles...
of course Steeda sells one too...
http://www.steeda.com/products/steeda_oil_separator.php
If you are smoking really bad...could be something else, but try this set up and see if you are still having leaks...I did not run a PCV and was pissing oil out everywhere...had to replace my lower intake gasket as well...once the PCV hooked up all Set...
Old Dec 12, 2007 | 06:10 PM
txstroker's Avatar
txstroker
Thanks for the replies I reley thought I did some damage but if thats all i got to do than hats off.
GimpyHSHS
19
Dec 19, 2023 01:12 PM
mrtrodonet
Sep 19, 2020 03:12 PM
svfetter
Oct 5, 2015 11:39 AM
lmurf60
Sep 24, 2015 10:07 PM
Ipaman
Sep 22, 2015 07:01 AM
