Pipes, Boost & Juice Talk about Exhaust, Nitrous, Blowers, Turbos, Superchargers... whatever makes you go faster!
how do i tune a turbo kit
Old Mar 14, 2008 | 08:02 PM
89foxmustang's Avatar
89foxmustang
Default how do i tune a turbo kit
Im thinking of putting a turbo kit on my 89 fox. What tuning things do i need to consider? I have purchased a boost retard device from crane that can be used with a map sensor to to proportion it to boost........
Old Mar 15, 2008 | 05:04 PM
P.S.I.cho's Avatar
P.S.I.cho
Default RE: how do i tune a turbo kit
if you want to run a MAP sensor and tune it efficiently this throws simpy putting a chip in out of the equation, you will most likely want to run mike andersons piggy back system PMS, with the MAP sensor add on an exta $75 or so, or you can spend a little more money and run a complete standalone, but honestly why go through all that trouble is its a nearly stock application?
Old Mar 16, 2008 | 05:24 PM
89foxmustang
its stock. I do have the map sensor for the crane ignition
i have a crane hi-6 ignition, timing retard device and crane map sensor. what else should i use?
articman
Jun 21, 2018 11:45 PM
Granatelli Sales
Mar 25, 2016 08:01 PM
Granatelli Sales
Dec 27, 2015 06:28 PM
copestang
Oct 11, 2015 07:17 AM
Boostaddict
Lethal Performance
Sep 8, 2015 09:56 PM
