When you SC your mustang...
Mainly you blow up your engine from any type of forced induction because you get greedy and try to run too much boost/too big of a shot (nitrous oxidide)
Another one is running too much boost without an intercooler which leads to preignition.
Another common one is having a ****ty tune or no tune at all. This will lean the engine out and...yeah its bad.
ORIGINAL: mikev08826
When you SC your mustang and don't do it correctly, what exactly get's f'd up? I understand the engine get's "blown," or whatever, But what specifically?
well, blown is sometimes used to mean you've got a blower(supercharger) on it.
blown up on the otherhand is a mess of problems. You can have spark blow out (like a candle). You can melt pistons, You can have detonation which is when the air/fuel mixture goes off from compression instead of the spark (adding fuel will correct this). You can throw a rod or worse, crack the block or head. At the very least you could head gasket.
I have a question how much psi can you run on a 90 lx engine to keep it safe running on 93 octane. I am going to be buying a 90 lx, the motor is already bored .030 over, probe forged pistons, e cam. I want to put a 2.2L KB on it running bout 12psi. Also I was wondering what compression ratio I could do that with. Would the stock 9 be ok?
Sorry, what I really meant is 12psi ok om 91-93 octance on the stock 9:0.1 compression ratio or would you suggest lowering it a lil bit. Also I was wondering if it was true that a 90 5.0 had a forged crang and rods from the factory?
evol04gt
Oct 30, 2005 04:40 AM
skinsr4reel
12
Jul 22, 2005 12:48 AM
