help with my new nos kit!
I have the same kit as this http://cgi.ebay.com/ebaymotors/2-NOS...3286.m14.l1318it has two n2o solenoids with that valve in the middle, what do I run into that middle valve, and It has a 47 jet in the fogger, does anybody know how much of a shot it is on a dry kit? O and the solenids are nos super powershots. any help would be great!
RE: help with my new nos kit!
thats a 5115 dry kit, the part in between the selonoids is the nitrous reg , it runs to the vac line off the fuel pressure reg
w/ a .047 in the nozzle you want a .053 in the vac tee, that will be 100 shot
.042 in the nozzle and .059 in the tee is 80 shot
.067 and .042 in the tee is 150 but over 125 you need to shim the spring in the reg to run properly
here is the pdf file install manual for that kit. plenty of pics and info
http://www.holley.com/data/Products/...A5130-SNOS.pdf
also look here for pics....same kit even though i have an edelbrock bottle
https://mustangforums.com/m_639288/tm.htm
i've done 3 now so i can knock one out in a bout 2 hours total. first time doing it counting beers in between and stuff... expect 5 hours just cuz you'll be double checking part numbers and such. afteryour doneyou can cut your time in half probably just from doing it once
here is a et slip from my '89... so you can compare NA to spraying , this was only jetted at 75 i'm pretty sure. try to run him a full 1/4, you'll have the advantage for sure.my car should be pretty comparable to you
motor
spraying
motor
spraying
