Can I used my Underdrive Pulleys with a Supercharger?
I have a basically stock Saleen S-281 with underdrive pulleys. I was told i need to swap the alternator, crank, and water pump pulleys back to stock to enable the supercharger to work properly.
is this true?
is this true?
water pump & alternator pulleys have nothing to do with the supercharger. The diameter of the crank pulley and the diameter of the s/c pulley do. The bigger the crank pulley the faster the impeller will spin with means more psi (up to the trim's limit) likewise, the smaller the s/c pulley the higher the speed.
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
