VORTECH V-1 HELP SPARK PLUGS
I was wondering if someone can help me out and tell me what spark plugs to run on a v-1 2002 mustang gt. i looked up ngk6 plugs but alot of diff. parts numbers come up. any help please let me know what parts numbers are u guys running on you sc stangs thanks
I ran platinum plus for a year and never had a problem. I went to Pep Boys once and asked them what plugs they used in the 03/04 cobra's, just to give me an idea on which plugs I should use,( because of the supercharger ). I was always told a 1 degree cooler plug with forced induction. Pep Boys tells me that the platinum plug was a direct oem replacement plug.???
Right now I'm using regular Autolite copper plugs. I can't tell the diff. between the two.
Maybe I'll try the NGK TR55's next year.
thanks i been waiting a long time. i ended up buying autolites double plat. expensive but it was last minute. i already have my car at gtr performance and should be getting it back monday i cant wait....... 400 plus hp to the crank. this forums really helped i bought every part by it self and the total cost of install tune and parts is 2900.
well its it installed but what crazy is that the dyno said 8.67 psi but the auto meter gauge only puts out 5 psi at best at wot. i told gtr safe tune... i have the parts to hit 380 plus but since my motor is 100,000 plus i wanted it safe. Also do you guys get alot of back pressure out of the exhaust. i dont have a brand exhaust its custom lol na just removed the muffers and add x pipe. it seems to back fire if i left of the throttle in every gear except 5th.
