help me with intercooler
im trying to find a intercooler for my car,on ebay theres alot of them and i want the procharger one because i heard you dont have to cut anything. I cant find any for a 02 gt. Also if i did go with an ebay kit what size tubes should i go with 2 1/2 or 3inch. I figured 2 1/2 would be easier to fit but i dont know if i'll lose any power rom the smaller tubes. Does it matter that the air is traveling through longer tubes,or is that not anything to worry about and one last thing i saw in the one thread about turning the supercharger to face down, is this as simple as loosening some srews or do i have to drill and tap new holes. Btw i have a vortech v2 s-trim
unless you buy a full kit you'll always have to cut something - if you just buy the intercooler no matter what kind you get you'll have to mock up the tubes for it. The cheaper ones are said to be just as effective - I havent tried yet though. Ebay has lots of good intercoolers for under $200.00
thats what im looking at, any ideas on the size, im thinking 3inch and also about turning the sc down, it looks like all you have to do is tak a couple srews allen head screws out and turn it but i want to make sure before i start taking everything apart
http://cgi.ebay.com/ebaymotors/CXRac...Q5fAccessories
That is the kit you want. Put in an offer of $200 and you should win it. You will have to reclock your supercharger so it is pointing down. You are correct in assuming you take out the allen bolts to do this. There are 2 pipes you will have to cut along with spacing out the bumper support (I used 4 pieces of 1" Aluminum tubing cut to 1.5"). You will need longer bolts for that as well. You will have to make the hole bigger where the intake pipe goes into the fender area. All in all, took about 4-5 hours. Is a great kit, only downside is the psi drop over the intercooler. I had a 3.60" pulley at 10.5 psi. Went to a 3.25" pulley after the install and saw 9.75 psi. There you have it my friend. Good luck, it is a fun little project. I really enjoyed doing it.
i found that i have 38lb injectors, if i get the 3.25 pully what would i be looking at before and after with the intercooler(for psi), a rough idea is fine. Right now im running 7-9 psi and was thinking changing the pulley for now and then doing the intercooler over the winter.
It's gonna cost more $, but I would get a paxton or a good turbo intercooler and be done with it. I have seen to many guys decide to upgrade later from a cheapo ebay intercooler I am using a turbo intercooler from www.modularpowerhouse.com
I got the 750hp one, but they have a 600hp version that is cheaper.
Later,
Derrick
Later,
Derrick
It's gonna cost more $, but I would get a paxton or a good turbo intercooler and be done with it. I have seen to many guys decide to upgrade later from a cheapo ebay intercooler I am using a turbo intercooler from www.modularpowerhouse.com Here is the link to the kits. http://modularpowerhouse.com/index.p...9e04fb5e89d57b
Later,
Derrick
Later,
Derrick
SANDY21
Aug 17, 2015 02:41 PM
