im excited to get the dyno done to see what kind of number im puttin down, where do you guys think i will be? considering he said he did a "very conservative tune"? i was hopin for around 350whp. like i said the only other mods i have are 1 chamber muffler and a magnaflow x pipe
my buddy has a 2004 gt with a v2 non aftercooled stock 3.60 pullie, 75mm throttle and plenum, o/r h, flowmaster 40 2chamber, everything else is stock including headers/manifolds ect... his numbers were on 6 lbs of boost (you average that with stock 3.6) but he had bad 02 sensors so they had to do a conservative tune like yours and we are down in florida so he was dynoes at 100 degreeze and 100 % humidity and his numbers were 347/352, now he is going to replace the 02's and add the Anderson Power Pipe and his tuner told him to expeact and increase of 35-45hp. and to also run a meth kit because of the non intercooled.
so i guess i was pretty close with my guess of 350whp. does the anderson power pipe really make about a 40hp difference? if so, i think i will be looking into that gettin one...
no, the pipe adds about 1-2 psi of boost and 20-25 hp but when they can actually adjust his timing its gonna make it about 40
