Pipes, Boost & Juice Talk about Exhaust, Nitrous, Blowers, Turbos, Superchargers... whatever makes you go faster!
Meth Injection Nozzle placement
Old Dec 19, 2009 | 06:33 PM
vanbibber's Avatar
vanbibber
Default Meth Injection Nozzle placement
Where's the best location for Alcohol Injection Nozzle? I spoke with a guy at Alcoholinjectionsystems.com, and he advised me to run a duel nozzle setup. One 14gph nozzle pre-supercharger location after MAF, and one 5gph nozzle right before the throttle body. Does this sound right to you? I'm pushing 450 - 500 rwhp at 14 pounds of vortech boost. I'd like to hear your thoughts.
thanks, -tim
Old Dec 21, 2009 | 09:38 AM
vanbibber's Avatar
vanbibber
I was thinking about the IAT Sensor, wouldn't you want the sensor to be right after the meth injection and right before the TB so that it'll get a true indication of the air temps entering the intake so the computer can make adjustment accordingly, ie.. add/pull timing, fuel etc..
Old Dec 22, 2009 | 03:29 AM
luckythirteen13's Avatar
luckythirteen13
they recommended 2 nozzles for that low of hp?
Old Dec 22, 2009 | 07:52 AM
vanbibber's Avatar
vanbibber
That's what I was thinking, I called them again because I was a little leary and a different tech reconfirmed the duel nozzles, 14gph before vortech and the 5 before TB. They said the've done hundreds and hundreds of systems this same way.
Old Dec 22, 2009 | 09:44 AM
vanbibber's Avatar
vanbibber
After reading over my notes, they said the 14gph = 882 ml/min pre-charger, and a 3gph = 189 ml/min pre TB. just seems a bit much, but with talking to two different tech's saying the same thing, i'm assuming they know their product and it's uses. I'll just bump up the presure switch to 10lbs before the system turns on.
jwog666
Dec 27, 2021 08:09 PM
rksnow1
Sep 14, 2015 08:46 PM
Soldier GT
Sep 8, 2015 01:28 AM
MusBBad95
Aug 17, 2015 09:39 PM
