Pipes, Boost & Juice Talk about Exhaust, Nitrous, Blowers, Turbos, Superchargers... whatever makes you go faster!
Intercooler
Old Aug 26, 2005 | 04:08 PM
MustangChris04's Avatar
MustangChris04
Default Intercooler
I was talking to this guy at out local hangout, and he was talking about this "new" technology where you dont need an intercooler. He said you fill your winshield wiper bucket with some sort of alcohol, and a tube runs to that into a part where the turbo is to cool the air. He said the performance is better with this "cooling device."
Is this BS? I didnt get the whole story he said, but has anybody heard of such a thing?
Old Aug 26, 2005 | 05:17 PM
josh_0351's Avatar
josh_0351
Default RE: Intercooler
That sounds like a line to me....
Old Aug 26, 2005 | 05:55 PM
JD1969's Avatar
JD1969
Pro. B.S. caller outer
There is such a thing as a water to air intercooler, but it is as big and in most cases bigger than a conventional intercooler. Sounds like you met a professional bench racer, they to hang out cruise nights and car shows, but, mysteriosly you never see them at the track and there car alway "apart".
Old Aug 26, 2005 | 06:40 PM
nanaki's Avatar
nanaki
Retired MF Moderator
someone from this forum has that thing that you fill with the window washer fluid, not alcohol though. it cools it a lot and it's like running like 109 octane or some ish. i haven't really researched it, but someone here has and actually got one installed. maybe he'll peak his head in.
errr.. isn't that stuff called methenal or something? yeah.. i think that's it. whatever is in that window washing fluid, it's half water and half of that other stuff, which is what that intercooler kit uses that that guy is talking about.
Old Aug 26, 2005 | 11:16 PM
MustangChris04
methenal rings a bell. I think it was that. He said its kind of like alcohol. He also said you can also use it as wiper fluid so he hooks it up to his wiper fluid container.
Old Aug 27, 2005 | 02:49 AM
nanaki's Avatar
nanaki
i don't know if it's alcohol, but yeah, that's what it does. bicketybam is the one that has one of them intercoolers. here's some links to a couple.
http://www.coolingmist.com/detailpage.aspx?pid=02P
http://www.snowperformance.net/products.asp?id=1 (Boost Cooler)
http://www.andersonfordmotorsport.co...e_content.html (Mr. Freeze)
Old Aug 27, 2005 | 12:46 PM
FoxGT's Avatar
FoxGT
Methanol injection. Methanol cools the intake charge the most, but the downside to it is it will slowly corrode your plastic parts. Most people use the setup with just water which has two good sides 1. It cools the intake charge quite a bit 2. It will help clean the carbon out of the engine. The only setup I've seen activates at WOT, when not at wot the water never touches the intake.
Old Aug 27, 2005 | 03:22 PM
2000GT4.6's Avatar
2000GT4.6
ORIGINAL: XbcSharpShooter
It is called methanol injection. Snow performance makes a good kit. It allows you to run more timing than you could before.
Old Aug 27, 2005 | 04:44 PM
Blk_96_GT's Avatar
Blk_96_GT
i think it was mm & ff or 5.0 that instaled it and they got like 60Hp out of it. i would def have a intercooler also though.
Old Aug 29, 2005 | 12:31 PM
FoxGT's Avatar
FoxGT
ORIGINAL: Blk_96_GT
Most people do that if they want to run 20+ psi on pump gas. Someone I know is running 26 psi on 93 octane using methanol.
Bokeo
Oct 10, 2015 08:28 PM
Explosive
Oct 2, 2015 07:45 AM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
2015Ecoboost
Sep 17, 2015 01:48 PM
SANDY21
Aug 17, 2015 02:41 PM
