High Octane on Nitrous
While running my car on just motor, i need 93 octane or it wont run right, so if i also run nitrous would i need a higher octane for it to be efficient? On just about any shot, its at a 100 shot and it runs fine, but would i be better of with say 100 octane or 110 or what? Lets say i went up to a 250 shot, what would be the best?
ORIGINAL: redmustang83596
Dan said it in his post, if it hasnt been tweaked and it doesnt run correctly on 93, then somthing isnt right to begin with. If your running a 100 shot or above I would recommend you get the car on a Dyno anyway.
ORIGINAL: 94Cbra
In that situation it would be best to call a tow truck...
i have a 86 GT and its not anywhere near stock the car is built strrong and handles nitrous like its nothing, in other words no tow truck is ever gunna get called, blowing up a motor on nitrous is a myth if you know how to use it, i ran my 250 shot twice and once was on pump 93 with octane booster and it worked really good.. the second time it was on just pump 93 and i had pre-ignitoin all the way down the track.. this is why i was asking the question cuz it ran fine with the higher octane.. the car is set up for a 100 shot using just premium gas and it works like a champ, i just wanted to be able to spray bigger cuz 100 isnt enough
my plugs are two heat ranges colder then stock, its the coldest plug that autolight offers, also the gap is set a lot shorter and it drilled down a little bit cuz if too much nitrous comes in, it can blow the spark out, my internals are forged and all that junk, and i have plenty of safetys put in place, i dont spray before 3K rpm, i have 4* initial timing taken out and then i have a msd box that pulls more timing out when i actually do spray, the car is safe and prob wont blow up, its a plate kit that sprays fuel along with nitrous also and i also have a out of tank 255 Vortech fuel pump thatll pump out any amount of fuel that ill need, so im not worried about there being enough fuel, im jsut worried that the octane will be too low and not burn all of the nitrous and then the bad stuff happens..... as far as a tune goes, its got a very very basic tune, no time on a dyno or anything like that, so thats another thing i am kinda worried about, its not perfected its kinda like a trial and error type of deal
