question about centrifugal superchargers!!!
RE: question about centrifugal superchargers!!!
ORIGINAL: v8musclecobra
And is it tru that you can put 2 centri- superchargers at like 20 psi each to run like 40psi on pump gas and have double the power??
ayt i just wasnt sure thats y i posted it. I thought that you could do a twin centri- set up... how come you can do 2 turbo's but not 2 centri's?
ORIGINAL: blueangelfightr
It's because of where they are mounted. Turbos are mounted down and to the front. Centifugals are mounted up top and to the front. You have to move stuff in the engione bay as it is, if you had two you would need to move everything on the other side also, there's just not enough room.
what if you moved the battery to the trunk, ran the intake down, and got a bigger hood?
ORIGINAL: Birdieman4
The faster you spin a centrifugal blower, the sooner the boost comes in. If you were running 20+ psi on a Procharger P1sc, the boost would come basicly at the hit of the throttle. If you are running a cetrifugal blower and making 8 psi and you decide to swap pullies and run 10 psi, you will notice the boost comes in a little quicker.
true. id prob have to do a **** load of new internals 2 cause thatd add like an extra 400hp. but i think ill give it a try, and possibly keep a kenne bell on the center 2 if its at all possible. thanks 4 the help.
so what are you better off doing then? Money isnt a big deal for the twin charger set up cause my friends brother owns his own shop and does it for little to nothing.
why would 2 superchargers run the same as one and cancel one out?
o i definetly will. Could you run the 2 centri's with a kenne bell also. If i did it it wouldn't be for a while just wondering if it was at all possible, caus ethatd be insane.
i know lamborghini make a twin supercharged car... i saw a video of it with 700hp and AWD.
FOX you should erase the sentence you have above your signature because you sure do explain things well to people who ask somewhat rediculous questions! which is a good thing
