Pipes, Boost & Juice Talk about Exhaust, Nitrous, Blowers, Turbos, Superchargers... whatever makes you go faster!
Wanting a twin turbo
Old Apr 16, 2012 | 05:21 PM
Unique's Avatar
Unique
Default Wanting a twin turbo
Hey guys thanks in advance! On a 95 mustang gt with 150000 on it only aftermarket performance part is a cheep cold air intake. I eventually want to put a twin turbos running 8-12 pounds of boost out of each as to retain the intergrity of the turbos and supply plenty of boost. My question is what do i need to do to engine to prep it for such boost ie. rods heads any suggestions would be great. And how much horse power is to be expected? Prices would be nice too. Again thank you
Old Apr 16, 2012 | 08:50 PM
luckythirteen13's Avatar
luckythirteen13
How much power do you want to make?
Old Apr 16, 2012 | 10:23 PM
Unique's Avatar
Unique
between 500-750 hp i know thats a wide range but idk if 500 will be enough and anything over 750 is not practical for a street car. Also will the stock rear end hold up?
Old Apr 17, 2012 | 12:57 AM
luckythirteen13
if you have any traction the stock rear can break. with 150k on the clock your over due for bearings at the least and the trac loc is probably tired. the stock axle studs can snap too with a hard enough hit of traction/power.
what tranny? if auto, you need to build it for any hp level. if stick, as long as you never power shift and get a good clutch, its hit or miss as to if itll survive.
id be comfortable with 550rwhp with the stock block, any more and you need a fully built motor including a race block.
youll also want full suspension. stock suspension sucks at stock hp levels. throw 750hp at it, and youll have nothing but a burnout machine.
basically plan on building an entire car to do it right.
AMAlexLazarus
AmericanMuscle.com
21
Apr 4, 2020 02:16 PM
richard1027
Sep 9, 2015 07:23 PM
baron95
Sep 6, 2015 09:24 PM
SXGT
Aug 31, 2015 01:28 PM
GimpyHSHS
Aug 29, 2015 06:30 PM
