high compression with blower?
just a quick q. somewhere, can't remember where but i heard that the more psi you add in a blower the higher compression you need. i've heard it both ways. just trying to clairify a couple things.
you can go as high as 10:1 compression with 14 PSI with forged internals. i have seen two GTs with that at the track, they both ran very similar times, and i know the one guy drives his on the street to and from work until the $3.49 for premium.
i have seen 22:1 compression and 90 PSI before, on a diesel, stock and wastegated.
ORIGINAL: matthockey32
ORIGINAL: JD1969
Why would you add this? It will only confuse people, as a diesel works on totaly differant principal than a gas engine.
"The more compression you have, the less boost you can handle."
mungodrums
Suspension
Sep 24, 2015 10:12 PM
