Pipes, Boost & Juice Talk about Exhaust, Nitrous, Blowers, Turbos, Superchargers... whatever makes you go faster!
headers install
Old Dec 30, 2005 | 07:29 PM
yeayea0's Avatar
yeayea0
Default headers install
How much do you think a headers and h-pipe install would be on an 01 cobra?? Also do I have to go to a specialty shop for this or is it a common install for places to do?
Thanks
Old Dec 30, 2005 | 10:35 PM
luckythirteen13's Avatar
luckythirteen13
Default RE: headers install
try it youself and save the money. ive heard of people paying $300 plus
Old Dec 30, 2005 | 10:57 PM
1BAD3V's Avatar
1BAD3V
I would try and do it yourself first. I have heard as much as $500 for just the headers. Good luck on finding a good deal if your having a shop do it.
Old Dec 31, 2005 | 12:08 AM
sprostang's Avatar
sprostang
I ♥ Acer
Its gonna be a total PITA to do yourself. Plan on a good days worth of work. Your gonna need to remove the mid-pipe first. Then remove the EGR pipe fitting. Then pull the starter and steering shaft. Then work on the removal of the stock manifold. You may need to remove the engine mount bolts as well to raise the engine (using a floor jack) therefore, you will get better access to removing the bolts on the manifold. [:@] Good luck..
SSG Steggy
3.7L V6 Technical Discussions
Nov 5, 2015 03:09 PM
Luke9222
Oct 22, 2015 11:55 PM
Boostaddict
Lethal Performance
Sep 8, 2015 09:56 PM
Luke9222
Sep 4, 2015 06:46 AM
