Pipes, Boost & Juice Talk about Exhaust, Nitrous, Blowers, Turbos, Superchargers... whatever makes you go faster!
gears
Old Jan 4, 2006 | 08:41 PM
RiCe_KiLlEr's Avatar
RiCe_KiLlEr
Default gears
I have a 2004 mustang gt, stock for right now, im gonna be gettin an o/r x-pipe and slp loudmouth II exhaust, CAI and upper intake plenium with a 75mm t/b. Now I was just wonderin what would be the best gears to get for at the track??
Old Jan 4, 2006 | 08:59 PM
nanaki's Avatar
nanaki
Retired MF Moderator
Default RE: gears
4.10s. this shoulda been posted in pb&j
Old Jan 4, 2006 | 09:33 PM
MustangChris04's Avatar
MustangChris04
Default RE: gears
if your planning on doin a lot more to your car then 4.10 wouldnt be the way to go. You will run out of gear on the track. but for street 4.10 is nice
Old Jan 4, 2006 | 09:43 PM
nanaki's Avatar
nanaki
Default RE: gears
haha. he's not going to run out of gear at the track. not unless he plans to trap higher than 140MPH.
Old Jan 4, 2006 | 09:55 PM
MustangChris04
Default RE: gears
wtf? im getting 4.10 and i did the calculator and my top speed in 4th was around 115. If I was racing someone and went into 5th they would fly right past me.
Old Jan 5, 2006 | 02:48 AM
czwalga00gt's Avatar
czwalga00gt
Default RE: gears
ORIGINAL: nanaki
You dont use 5th gear , its an overdrive and is not even located in the same place in the tranny as 1-4 gears. 4th runs out around 115.
Old Jan 5, 2006 | 08:51 AM
nanaki's Avatar
nanaki
Default RE: gears
ORIGINAL: czwalga00gt
ORIGINAL: nanaki
well, if i'm at the track and i'm redlining 4th (doubtful unless i forge my bottom end and run some massive boost to move my car), i'm not going to let it keep going and bounce off the rev limiter. i'm going to shift into 5th or go into neutral. doesn't look like you're running out of gear at the track yourself either.
Old Jan 5, 2006 | 09:15 AM
1BAD3V's Avatar
1BAD3V
Default RE: gears
I'd get the 4.10's if your going N/A. But if you plan on turbo or s/c, I would suggest you get 3.73's.
Old Jan 5, 2006 | 09:41 AM
nanaki's Avatar
nanaki
Default RE: gears
if you were going with an s/c, i'd suggest 4.10s
Thunderball
15
Nov 22, 2015 11:49 PM
Bokeo
Oct 10, 2015 08:28 PM
KingRando
Oct 2, 2015 08:06 AM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
junior04
Sep 28, 2015 10:53 AM
