Pipes, Boost & Juice Talk about Exhaust, Nitrous, Blowers, Turbos, Superchargers... whatever makes you go faster!
eaton VS. KB
Old Jan 16, 2006 | 05:00 PM
Birdieman4's Avatar
Birdieman4
Default RE: eaton VS. KB
Probably cheaper, but you'll still have the roots powerband. The KB is a great swap if you can afford it.
Old Jan 26, 2006 | 09:42 PM
metaldrummer's Avatar
metaldrummer
looks like im going KB then. or what about a T76?....
Old Jan 26, 2006 | 10:17 PM
mysticsvtcobra96's Avatar
mysticsvtcobra96
Sorry about that Birdieman4..i thought you were talking about the m112 on the 03 04 cobras....and the t76 single turbo is always a good idea..it will make more power and put less strain on your engine when your just crusing around
Old Jan 27, 2006 | 06:29 PM
metaldrummer
however, my car wouldnt spool the turbo very quickly the mods listed in my sig. i mean, without the supercharger, ill have almost no low end torque which means ill be 100X slower off the line -how can i solve that problems if i go with the turbo?
Old Jan 27, 2006 | 06:54 PM
Fallstar01's Avatar
Fallstar01
If you get the KB, you can probably save a little money since you already have a front heat-exchanger, pump, resovoir and lines. Also, you should be able to get some money back if you sell the Series II along with the 30 ft/lb injectors.
Old Jan 27, 2006 | 07:12 PM
nanaki's Avatar
nanaki
Retired MF Moderator
ORIGINAL: metaldrummer
how do ya figure? you're "spooled" by 3000rpm, maybe less with a turbo. how long does it take you to get up to 3000? even when my GT was stock, it only took a second.
also, if you went with a KB instead of a turbo, you'd have all that power down low and spin more-so off the line than if you had a turbo. just somethin to think about.
Old Jan 27, 2006 | 07:27 PM
Fallstar01's Avatar
Fallstar01
Launch at 3500 RPMs with Slicks and the Turbo will have no problems off the line
Low end power isn't as important for drag racing. It's more useful for Autocross or even track racing where it really shines. It's also much more fun/noticeable for highway and around town driving.
Old Jan 28, 2006 | 12:50 AM
Closkey's Avatar
Closkey
ORIGINAL: codyss
The Eaton units were choosen for OE reliability and function. The KB was desinged for raising hell.
hah I like that.
Diode Dynamics
28
May 26, 2022 12:02 PM
JT76
Sep 20, 2015 11:32 AM
yurizx6r
Sep 7, 2015 06:40 PM
killer03cobra
Oct 6, 2004 11:44 PM
