eaton VS. KB
eaton VS. KB
heres my dilemma. my car came stock with the eaton m90 and im getting ready to install a forged rotating assembly so i can run 13-15 psi. i know the roots blowers make a ton of heat and become inneficient at high psi and that KB SCs are very efficient. my question is what would the hp diference be between my intercooled eaton m90 at 14 psi and the intercooled KB 1.7 at 14 psi.
RE: eaton VS. KB
First of all, the most boost you'll see out of the M90 is around 12-13 psi. -And that's spinning it really fast. But, lets say we compared the rwhp in both @ 13 psi. The M90 would give you around 410 rwhp, and that's tuned well. The kb would give you around 480 rwhp at the same psi, tuned.
RE: eaton VS. KB
well KB with the same size of pulley as the eaton will have anywhere from 40-60hp or more hp than the eaton and im sure with the intercooler it would be even better numbers. KB is just a all around better supercharger why else do u think everyone with a 03 04 Cobra swaps eatons for a KB. KB you could even run more psi if you want because the supercharger can handle it. By the way if you sell the M90 and manifold give me a PM i would be very interested.
RE: eaton VS. KB
the eaton is becomes very hot and very inneficient very fast, hence it being known as the "heaton". when it comes right down to it, an SC is an SC and it awsome to have regardless but when you want to make the big numbers you need to discriminate a little.
and red, yeah ill pm you if i end up selling it.
RE: eaton VS. KB
where do you get 13 psi is the most your going to get?Ive got the 2.80 and im running 14psi and still could put a lower pulley on the crank after the port job on the s/c..save your 4 grand for a kenne bell and get some head work done
RE: eaton VS. KB
RE: eaton VS. KB
My Cobalt SS is running 12.5 pounds of boost via a Eaton M62 which displaces 1.00 Liters. Thats alot of boost for a M62 not to mention a 3.00 pulley will bump it to 15psi and a 2.80 will take it to 18psi. After that it is getting really close to it's max rated speed of 14,000rpm's. In either situation if it wasn't for a very effcient heat exchanger you would see alot of heat and less HP.
The same methods and mechanics can be applied to the M90 and the 03/04 Cobras M112.
The more boost you can get out of less RPM's the better.
The Eaton units were choosen for OE reliability and function. The KB was desinged for raising hell.
RE: eaton VS. KB
would it be cheaper to port out my eaton for more displacement, add a smaller pully, and get a really good heat exchanger instead of buying a KB? my goals are 600 rwhp daily driven.
