Pipes, Boost & Juice Talk about Exhaust, Nitrous, Blowers, Turbos, Superchargers... whatever makes you go faster!
flip chip
Old Jan 15, 2006 | 01:05 AM
jlauth's Avatar
jlauth
Default flip chip
I was planning on getting a SCT x cal 2, but with the nitrous comming i didnt know which would be better just a sct or a flip chip. I know nothing about these flip chips could just put 3 tunes on your sct. Is this flip chip even needed or could i just have a good tune that would work with nitrous and Daily driving. my car has only bad AFR problems, because of the o/r h pipe and the crappy mils that dont work. If i just could get the check engine light i would not even need to speend money on a tuner. So is a tune or flip chip even needed, and if any one has any info on the flip chip i would like to better understand. thanks
Old Jan 15, 2006 | 03:15 AM
nanaki's Avatar
nanaki
Retired MF Moderator
Default RE: flip chip
http://mustangtuning.com/sct-4-bank-computer-chip.html
http://mustangtuning.com/sct-coin-ho...1999-2004.html
get that janx. you can switch to your nitrous tune on the fly, as well as other tunes. like if you're taking a highway trip and wanna run regular (87) gas. or you're at the track running the bottle.
if you're just worried about your car throwing a car because of the o/r midpipe, you can get a set of MIL eliminators and that'll kill it.
Old Jan 15, 2006 | 12:24 PM
jlauth's Avatar
jlauth
Man i have the MILs and you could just say that they will work for a week at the most. So i know that the CEL comes on because of the O/R pipe, but would that cause the AFR to go south.
Old Jan 15, 2006 | 01:46 PM
bryanec's Avatar
bryanec
If you get a xcal2 you can turn off the rear o2 sensors and do a lot more. You can also load 3 tunes in it, you just cant switch on the fly. Be carefull which dealers you buy from because they will be your main support for tunes.
Diode Dynamics
28
May 26, 2022 12:02 PM
spectreman
Mar 31, 2016 09:26 PM
dubarado
Dec 23, 2015 01:16 PM
1TUFF302
Nov 5, 2015 04:02 PM
