GETTIN SUPERCHARGED THIS WEEKEND!!!!
well im going with spec stage 2 myself cause its rated up to like 520 ftlbs of torque... but stage 3 wont hurt ya. And yea tires..if u wanna get good times at the track...ive got MT ET Drags myself.
ORIGINAL: cubsalltheway
WOW!!! that is way more than i thought it would be. what clutch did you go with? i was thinking about going with the spec III but i am still undecided.
your ganna **** yr pants the first time your floor it, yr almost ganan be double yr hp numbers, I think a good idea would be a nice clutch, the stock one might not like all that power
One of the main things I recommend is a boost/vac gauge and a fuel pressure gauge. These will key you in to any problems that might be occuring.
Eventually you'll want to consider 31 spine axels but that'll also require that you get a new differential. For a differential, I'd just get the 31 spline version of the trac-loc. It's cheap, it works, and it's easy to rebuild.
i guess that i will hold off on getting a clutch it cant take it anymore. i will def look into the stage II. how much hp can stage II handle? i am new to this so i am not too familiar with diffs. [:-] what will that do for me? what do you i need to look for?
finally took her to the shop. it should be ready by wed. i will post numbers and hopefully some pics also. too bad the weather is bad in chicago, cause i wanted to see what she's got.
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
