Pipes, Boost & Juice Talk about Exhaust, Nitrous, Blowers, Turbos, Superchargers... whatever makes you go faster!
vortech intercooler?
Old Feb 13, 2006 | 03:53 PM
00stang37's Avatar
00stang37
Default vortech intercooler?
im looking to buy a voretch s/c and i was wonder instead of getting the aftercooler, could you put an intercooler on instead? and if so would it work better or worse then the after cooler? thanks
Old Feb 13, 2006 | 04:00 PM
Davojan59's Avatar
Davojan59
Default RE: vortech intercooler?
im not certain on this but i think u can buy the non aftercooled vortech kit and order the intercooler from paxton....on any intercooler for that matter....but u probly will need some extra parts to fit them all in there.
Old Feb 13, 2006 | 04:06 PM
nanaki's Avatar
nanaki
Retired MF Moderator
yes you can. you'd have to fab it up. it'd be a lot cheaper than the aftercooler kit though.
Old Feb 13, 2006 | 09:26 PM
luckythirteen13's Avatar
luckythirteen13
it wont be a problem. after you mount the sc, mount the intercooler and then run the plumbing. if you cant tube bend yourself, you can buy pre-bent tubes and then cut and weld as needed
Old Feb 13, 2006 | 10:32 PM
trbuddy's Avatar
trbuddy
ORIGINAL: 00stang37
I'm looking at exactly the same issue. I did found the Paxton intercooler kit for about $1200.00 which I think fits my Vortech. I also found quite a lot of different aftercooler which fit my GT which range from $95 to $500. There are also some universal piping set out there for about $180.00. So if you have a little mechanical skills you can install a decent intercooler setup for about $400-$600 by ourself. And for how much does the Vortech aftercooler sale for ? about $1700 bucks? So for me no question.
Old Feb 13, 2006 | 10:35 PM
nanaki's Avatar
nanaki
there's places that sell different inter/aftercooler kits for vortechs for much cheaper? made specifically for a 4.6 engine with a v2 sq. i'd like a real inter/aftercooler made for my setup without having to spend almost 2k for the vortech kit [:@]
Old Feb 13, 2006 | 10:44 PM
angcobra's Avatar
angcobra
ORIGINAL: 00stang37
Are you looking for an air to air cooler or a water to air cooler? You should be able to use either one you want with any SC if you are willing to spend the time and effort on plumbing. If you have the SC mounted on the same side as your throttle body, it might be easier to go with the water to air. If it is mounted on the opposite side you could go with either one you want.
The SC vendors are confusing everyone with their sales names. Both the air and water coolers are actually after coolers with one vendor trying to use the name of inner cooler tagged for air to air.
Old Feb 13, 2006 | 10:49 PM
nanaki's Avatar
nanaki
i may be ordering the snow performance intercooler. cheaper and easier alternative.
Old Feb 14, 2006 | 12:29 AM
dajawu's Avatar
dajawu
Are you talking about the Boost Cooler? How are those? If you get one you need to get a new tun with it on correct?
Old Feb 14, 2006 | 09:53 AM
nanaki's Avatar
nanaki
snow performance boost cooler, yah. give them a call. i talked to some lady who totally knew her shat. i was about to propose to her.
