HOW TO: Rear Sway Bar Install *Pics*
#21
RE: Rear Sway Bar Installed *Pics*
i just found a pair of used GT sways. what additional hardware will i need to install? where can i purchase these parts? i found vendors with bushing kits, etc. but are these brand specific?
thanks
thanks
#22
You'll need the hardware for the rear sway bar. Hopefully they came with the bushings. You can get the hardware from your Ford dealer for an arm and a leg (seriously, like $70 for 6 bolts and nuts). Rear swat bar really stiffens up cornering.
#23
Moss Mustang has the bushings. Ford has the bolts.
Make darn sure the brackets come with the rear GT take-off sway.
$44-$50 for 6 bolts and 6 nuts.
The part #s are here:
http://iihs.net/fsm/?dir=65&viewfile...izer%20Bar.pdf
You want bushings for the 20mm GT rear sway bar.
[IMG]local://upfiles/69445/CB776B67987142FBAB44E9A61DD40C32.jpg[/IMG]
#25
ORIGINAL: Sancho805
thanks guys. damn....seems like the additional hardware parts will come out to cost more than the actual sway bars![&:]
Here is what should come with the rear sway PLUS
the end brackets that are not shown in the pic.
Coupes and Verts use different rear sways, so buyer beware.
https://mustangforums.com/m_5005054/tm.htm
[IMG]local://upfiles/69445/347036CAD99F495D909AF73B3947FEC0.jpg[/IMG]
#28
ORIGINAL: Sancho805
just talked to the seller and he said that the brackets were re-used for his aftermarket sways [&:]. do you guys know how much it is for the brackets?
Its a Ford item.
You can print the service manual page with
the brackets on itand take it in with you.
