Nitrogen ??
Old Aug 13, 2006 | 02:26 AM
05 Silvertible's Avatar
05 Silvertible
Default Nitrogen ??
Anyone running the green cap ?? Any dif or all BS ??
Old Nov 18, 2006 | 12:13 PM
jettblack06's Avatar
jettblack06
Default RE: Nitrogen ??
its bs. the only difference you get with nitrogen over normal air from a compressor is that nitrogen holds pressure better through temperature changes(like spring to summer, summer to fall, etc). its totally up to you
Old Nov 18, 2006 | 05:31 PM
AmericanICON's Avatar
AmericanICON
ORIGINAL: jettblack06
Ok.. you just said it's bs, then you pointed out it's advantage over regular air.
Old Nov 18, 2006 | 11:22 PM
MarioP3_XR4Ti's Avatar
MarioP3_XR4Ti
Nitrogen SHOULD not promote the introduction of moisture into the wheel/tire, and regular compressed air contains the moisture from the air around you which is then pumped into the tire/wheel assembly. Ever wonder why your expensive wheels are all pitted and crumbling inside if it's been several years since the tires were mounted? [he says remembering back to the BMW 750il we had with chromed alloy's. And when the tires were changed and the chrome started peeling off from around the bead and the stupid tires were leaking and going flat if it sat for any length of time - on a $80+K four year old car...]
Is it true that inflating the tires with nitrogen will do the things they claim?
I don't know, but it sounds like good logic and it probably can't hurt...
Jarrod@latemodel
LatemodelRestoration.com
Apr 11, 2012 09:19 AM
Jarrod@latemodel
Mar 2, 2012 01:19 PM
Blacksmoke
Nov 16, 2007 08:56 PM
Vulcan
Jun 26, 2007 10:13 PM
07 Stang
Apr 23, 2007 02:49 PM
