Sway Bar/Control Arm
Old Aug 27, 2006 | 11:09 PM
davidrc517's Avatar
davidrc517
Default Sway Bar/Control Arm
Hey, I have another newb question. You keep talking about sway bars and control arms and it seems like everyone has added them. Can you explain what these things actually do? Thanks.
Old Aug 28, 2006 | 12:48 AM
BlueStang6's Avatar
BlueStang6
Default RE: Swar Bar/Control Arm
Sway bars reduce body roll during cornering. Unless you have a 2006 Pony Package the V6 Mustang does not come with a rear sway bar stock. The benefit of a rear sway bar is huge because our V6's (without Pony Package) only have a front sway bar which is a built in understeer. The addition of a rear sway bar helps maintain a larger contact patch during cornering so that you can accelerate faster into a turn without sliding and braking.
A major area of weakness on the late model Mustangs (Fox , SN95 and S197 platforms) are the factory upper and lower control arms. The thin stamped steel arms offer little in the way of lateral stability, and combined with the large rubber bushings, the arms undergo considerable flexing. Under hard acceleration the stock arms and bushings sucuumb to wheelspin and wheel hop.
guitarman376
Oct 11, 2015 01:47 AM
UrS4
Oct 3, 2015 06:23 AM
winner99
Oct 1, 2015 10:52 AM
UrS4
Sep 30, 2015 10:13 AM
Sep 16, 2015 07:53 PM
