Just lowered my car, what else do I need
I just put a set of Ford Racing springs on my car and lowered it 1.5"
I had the front end alignment done and they got it to within a 1/4 degree of perfect is what they told me.
What else do I need to do to insure even wear on the tires and possibly take a bit of the stiffness out of the ride now.
Also how does a panhard bar benefit me, and how easy is it to install one.
RE: Just lowered my car, what else do I need
Read these threads:
https://mustangforums.com/m_1844066/tm.htm
https://mustangforums.com/m_1696246/tm.htm
https://mustangforums.com/m_1865547/...tm.htm#1867135
The panhard bar is what locates the rear axle side-to-side in the chassis. Most often if you buy an aftermarket one you get an adjustable one. This does two things:
1. Since it's adjustable you can properly center the rear end under the car.
2. The aftermarket panhard is stiffer than stock, which will help with traction/handling.
inyadreems
08-21-2015 09:10 AM
92 5.0stang
08-13-2015 06:46 AM
Milan Dragway
08-12-2015 03:43 PM
