Rear axle on bumps??
RE: Rear axle on bumps??
ORIGINAL: 2006RedGT
Thanks, when the funds come in this is what i'll be doing i guess. I wonder how install is $ wise. I can install a few things myself but some of these parts i would rather have a shop do.
It's a real poor design of the rear end suspension. Three link suspension set-ups, even with the rod are inherently unstable, and always will walk-around turns on the power and with a bump - just like the ole leaf spring set-ups. Ford could have done the design better with a four link set-up.
I would avoid he CHE control arms. They don't have grease fittings, which makes proper maintenance difficult. Also on the lowers the bushings aren't offset like they should be (though I heard they may have, addressed this latter issue).
I'm looking into the BMR LCA's right now. Just one question: which are stronger?........the tubulars, square cast, or billets? I was thinking the tubulars would be best.....and they are the cheapest. But are they the strongest?
I've been thinking of adding my own grease fitting, shouldn't be to difficult.
ORIGINAL: CrazyAl
ORIGINAL: moosestang
11-10-2015 11:39 AM
09-10-2015 08:39 PM
Dragonus18
09-09-2015 01:21 AM
