upper strut mounts
Old Nov 6, 2006 | 12:38 PM
Dont Try's Avatar
Dont Try
Default upper strut mounts
anyone that has had their car lowered did they have to replace the upper strut mounts as well? I heard they are a one time assembly and will pop if new ones are not installed??
Old Nov 12, 2006 | 12:23 AM
The Ghost's Avatar
The Ghost
Default RE: upper strut mounts
No. All is still good after a bunch of miles.
Old Nov 14, 2006 | 09:28 PM
06GT4RAD's Avatar
06GT4RAD
No need to replace the strut plates unless they are worn out. I heard that the nuts are one time use so i purchased some new ones but they take such little torque that i used the old ones and still have the new in the packages. No need to replace anything unless they are worn out. The strut plates are very inexpensive though so if you have any doubts they are only like 29.00 each
Richard
Old Nov 16, 2006 | 11:35 AM
moosestang's Avatar
moosestang
I didn't even remove the plates. I simply removed the large nut on the strut stud and released the compression on the spring using a floor jack. No popping or other strange noises. I also reused those nuts.
jwog666
Dec 27, 2021 08:09 PM
4cylinderplus2
Oct 9, 2020 07:45 PM
baddog671
Jul 26, 2016 01:20 PM
UrS4
Oct 3, 2015 06:23 AM
Explosive
Oct 2, 2015 07:45 AM
