adj. relocation bracket
Old Feb 12, 2007 | 05:36 PM
bchataroo's Avatar
bchataroo
Default adj. relocation bracket
I know the LCA's will help traction, but will relocation brackets help traction any if you are not lowered?
Just wondering.
Later
Old Feb 12, 2007 | 06:40 PM
CrazyAl's Avatar
CrazyAl
Default RE: adj. relocation bracket
Yes, they will, becasue they allow you to adjust your instant center.
However, this (like many suspension adjustments) is a tradeoff. The more aggressive you set them, the better traction you will get at launch. But, your ride quality on the street will suffer at the same time.
Google for "instant center" and you can read all about it.
Old Feb 24, 2007 | 11:19 PM
dly's Avatar
dly
Is there a big different in the Bolt ons vs. the Weld ons. I have a Mig welder in the Garage but would rather do the bolt ons if there is not a big different.
dly
Old Feb 25, 2007 | 11:50 AM
CrazyAl's Avatar
CrazyAl
Performance wise, there is not much of a difference. But welding them on is much more secure and solid--this is more of a safetyissue and "doing the job right". It's probably not needed unless you are running some really low 60' times, but it is the preferable option.
Old Feb 25, 2007 | 12:01 PM
dly's Avatar
dly
If I get the bolt ons can they be somewhat welded later on or could I just bolt on and weld the bolt ons??
dly
cr620
Oct 3, 2022 10:18 PM
baddog671
Jul 26, 2016 01:20 PM
flash_xx
Oct 16, 2015 07:23 AM
Oct 7, 2015 07:02 PM
Explosive
Oct 2, 2015 07:45 AM
