Sideway into a curb NEED HELP
I was messing around in the rain and went sideway against a curb. chiped the lip completely off. Noticed the wheel was wabling so I put on the spare and its still wable. So I don't think the rim is bent. But I'm not sure what is damage or bet because my brake squeak and wheel wable like its bent.
an axle is not going to be cheap at all.
http://newtakeoff.com/index.asp?Page...mp;ProdID=8175
then labor!
then labor!
is it in the front or the rear? you need to give a little more info, but then you dont call the doctor over the phone and expect a diagnosis do you?
do you feel the wobbling in the brake pedal or does the steering wheel shimmy? both?
you could have bent the control arm, rotor, tie rod end, busted the rotor, bent the spindle, all of the above.
the best answer you can get on here is that it is gonna be costly.
Dan04COBRA
Sep 30, 2015 11:46 AM
