coilover question need help
Old Feb 23, 2007 | 04:13 PM
AP2TUDE's Avatar
AP2TUDE
Default RE: coilover question need help
I think that the look is more of a driving factor for the average coil-over consumer than any other factor. Although nobody may be able to look and know exactly what the drop on the car was, the fitment that you can get with any set of wheels and tires can be much more specific than any particular spring. Now am I saying you can't get a good look out of springs? Of course not, you just can't tailor it like you can with something that is adjustable.
I think that if you are track savvy coil-overs offer a lot of performance advantages that you can't get from a spring and damper combination. Although a very small percentage of people out there take the time to corner weight their cars, this is a extremely advantageous performance enhancing tool that can really only be done with an adjustable suspension. And although you can get dampers which are adjustable separately, there are very few dampers out there which can be purchased for a specific application like the Mustang that will have a wide variety of adjustments, and even fewer if any at all which will be compression and rebound adjustable. Now should the average consumer go for anything like that? Of course not. These are parts which appeal to a very small percentage of the consumers out there.
Obviously each part is going to be better use in certain applications as well. Whether you are looking at a drag or a road race setup is going to be extremely important when choosing any suspension components as the demands placed on your suspension are going to be totally different between those two applications.
As for the spring rate, you made a very good point that is traditionally overlooked. The springs for any consumer level vehicle very rarely have a linear spring rate, which means that their rate is a function of stiffness and free height. As these springs need to be compressed a certain amount to attain their rate, the original height of these springs in conjunction with their rate does indeed effect the ride height of the car. But there are plenty of manufacturers out there who simply run a smaller spring with a higher rate in order to attain the same ride height. This is why from manufactuer to manufacturer you find differences in ride quality. Logically if everyone made springs with the same length and number of coils they should have the same rate, but with small changes in materials and designs they aren't all going to be the same. Close yes, but not equal. Because of these differences, pairing any set of springs with a set of dampers will yield results that aren't going to be as effective as if the dampers are valved with the specific spring rates in mind. Now once again...will the average consumer tell the difference? Probably not, but that doesn't mean that it isn't there.
Basically Al we are making the exact same point. The products which are marketed to everyone, aren't for everyone. There are upsides and downsides to every single part that you can put on your car, some are just more obvious than others. I think that they key when selecting any aftermarket component is judging all of the impacts that it will make to your vehicle dynamics and then weighing the pros and cons of those impacts. Not everything is going to be advantageous. I think that we are just trying to outline the way that the products work in order to educate everyone on what they really do, and how they do it. That way each suspension purchase can be made knowing what the full impact of every component is going to be. They shouldn't buy anything just because someone said it was good, they should get it because they know WHY it is good.
My little sisters boyfriend just dropped $4K on parts for his Evo. Intercooler, piping, exhaust, blow off valve (ugh), injectors....etc. I asked him why he didn't buy any type of engine management and he said he didn't need it. I asked him what injectors he got and he didn't know what size, or why he even got them. He said the guy who sold him the parts said buy this stuff and you will make this much power. Why it makes the power, he doesn't know. How it makes it...what each part does....nope...It seriously makes me sad. His car is awesome, yet he just bought stuff becuase he thought the parts were cool. I don't want to see that here. This forum is a huge source of educational info on everything under the sun. Take your time, read everything, and learn before you leap. The parts may fit your car, but that doesn't mean that they fit you.
Jon
Old Feb 23, 2007 | 06:24 PM
CrazyAl's Avatar
CrazyAl
Yep, it would seem we are in agreement! [sm=icon_cheers.gif]
Old Feb 24, 2007 | 04:30 PM
lindseyquads's Avatar
lindseyquads
ORIGINAL: steelcomp
ORIGINAL: RodeoFlyer
also not to be rude to you, but some things to think about here -
1. exactly how much do you know about the suspension on these cars?
2. europeans and imports are in no way to related to these cars - what they have done for them doesn't mean it's the same for S197's
3. are you hung up on the name? they are very expensive
4. Dominos' pizzamight be okay but their wings suck - stick with companies known for mustang specific parts
5. you're not likely to get the opinion of anyone on here that has them because more than likely none of us do
6. im assuming you want the height adjustablility, and if that's the case it's a hell of a lot of money to spend. Eibach would be a better choice for you.
bottom line - unless you are a hard core road racer they are a waste of money and effort for you. not to be rude to you either but if you're on here asking about them you more than likely don't fit in the genre that requires them. it's your money, but there's SO much more you could do instead.
Hey RF..."not to be rude", but you can be a real arrogant ***, sometimes. What makes you such an expert that you can tell someone that "because they are asking about coilovers, they don't "belong"?? Belong where, in your league?? LOL.
How many parts have you designed and built for your car? Are you an engineer? Are you a fabricator? How about a designer? Maybe you're a prefessional racer? Professonal race car builder?
How 'bout none of the above.
AFAICT...you've done nothing more than anyone else here...bought parts and bolted them on your car. BFD you autocross...that don't mean s hit. Maybe hit the "big" track on the weekend? OOooooh, my.
I'm really sorry, but I've read about enough of your arrogance here, and your insults and put downs to others who aren't any different than you. At one time, you didn't know s hit either, so try and lighten up a little, eh?
Thank you ,Well put couldn't have said it better myself
Old Feb 25, 2007 | 07:16 PM
alienmeister's Avatar
alienmeister
I think buyin coil-overs for the Mustang is pretty pointless except if you were taking it to a road course.
Old Feb 26, 2007 | 12:36 AM
lindseyquads
ORIGINAL: alienmeister
I think buying coil-overs for the Mustang is pretty pointless except if you were taking it to a road course.
Thanks for your opinion but if you read the original question, I am not asking which is better or whether I should run coil-overs vs. springs and dampener's simply asking if anybody is running this set up
Dokilar
15
Oct 16, 2015 08:13 PM
AMAlexLazarus
AmericanMuscle.com
Oct 2, 2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 10:29 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
treesloth
Sep 28, 2015 07:03 AM
