BMR Relocation Brackets
Old Mar 19, 2007 | 03:27 PM
leepinlen's Avatar
leepinlen
Default RE: BMR Relocation Brackets
thanks for the reply crazyal, I 've lubed the bushing with silcone grease and it quite down for a day or two and then starts again. I do notice that when I do jackup the side that squeaks I get a creaking sound/squeaking but I cant tell if its from the adjustment nuts which are locktite down or the bushings. Thanks again, bmr adj panhard, sphon adj lca, D-spec with BMR lowering springs
Old Mar 19, 2007 | 03:34 PM
CrazyAl's Avatar
CrazyAl
If you lubed the bushings then they shouldn't be squeaking. I would start looking for a part that is rubbing, or perhaps a bolt that isn't properly torqued down.
Old Mar 21, 2007 | 03:40 PM
ATNGRBR's Avatar
ATNGRBR
Is there only one position on the bracket you can put the LCA in?[/align]
Old Mar 21, 2007 | 04:16 PM
CrazyAl's Avatar
CrazyAl
No, there are multiple. That is the whole point of the bracket--to give you more adjustment choices for your LCA angle.
With the BMR brackets, there are a total of three positions available: Stock, and two others.
Steeda brackets have four choices: Stock, and three others.
CHE has only two choices: Stock, and one other.
Old Mar 21, 2007 | 05:28 PM
ATNGRBR's Avatar
ATNGRBR
Thanks CrazyAl! What position do you recommend for a 1.5" drop, it may be slightly lower than that.
Old Mar 21, 2007 | 06:36 PM
CrazyAl's Avatar
CrazyAl
The position depends on your exact setup (including tire size)...so I can't tell you what hole to use. But it is very simple to figure out for yourself:
With the car sitting on the ground (not on a lift) you want the LCAs to be LEVEL. The front of the LCA is fixed, so just put the rearward end of the LCA in whatever hole makes them level.
You can make the LCAs slightly lower in the rear if you want a more agressive launch, but this will also make your ride harsher.
More info in this thread: https://mustangforums.com/m_2727670/tm.htm
Old Mar 21, 2007 | 06:40 PM
ATNGRBR's Avatar
ATNGRBR
Thanks again!!
cr620
Oct 3, 2022 10:18 PM
baddog671
Jul 26, 2016 01:20 PM
Boostaddict
2.3L Eco-Boost Tech
Nov 24, 2015 06:11 AM
flash_xx
Oct 16, 2015 07:23 AM
Explosive
Oct 2, 2015 07:45 AM
