Squeaking sound from lower controls ?
There has been a sound coming from the rear end of my car.. im not exactly sure where it is coming from and why ? it usually comes if I step on it from 10 mph or after a speed bump ... it is coming more from the left side... so do u guys know what might be the problem ?
poly bushings? mine were squeaking like a BITCH!!!!!! so i gerased them, helped a little but not much... i took them off and manually greased them and theyve been alot quieter for now.
i suggest greasing them first, remember to use silicone base grease (i believe?) only anytihng else wears away the poly bushing
If you have spherical ends, it could benormal. Just make sure you are at torque spec. I have poly bushings and the same thing happened to me about a week after installing them. Got back under there and the side that was making noise loosened up some. Put it back to torque spec and no more problems.
129 lbs ft. Either take the bushings out and grease them by hand or at least loosen the bolts and then grease them with a gun. Do not grease them while they are torqued down, you can split the bushings that way.
ORIGINAL: scramblr
cuz I dont want to take it to a shop... it will cost me more+ it will take around 30 mins just to explain to the indian dude whats wrong...
Dragonus18
Sep 9, 2015 01:21 AM
