FRONT SUSPENSION NOISE WARNING!
Old Apr 28, 2007 | 03:32 AM
wolfey2k's Avatar
wolfey2k
Default FRONT SUSPENSION NOISE WARNING!
Anyone who owns a coupe or is considering purchasing a Mustang, please read this thread first!
You could be sorry you baught one or will be. Many of us are very frustrated regarding Ford's refusal to address and correct noisy front suspension problems caused by faulty parts.
Please read this thread!
https://mustangforums.com/m_2297319/mpage_46/key_/tm.htm#3126974
Anyone with the same problem, please join this thread too!
Old Apr 29, 2007 | 08:06 AM
mygt500's Avatar
mygt500
Multi-Tasking Moderator!
Default RE: FRONT SUSPENSION NOISE WARNING!
So this only happens to coupe's? Wasn't this posted somewhere else by you! There are many threads on this subject!!!!!!!!!!!!!!
Old May 7, 2007 | 04:01 AM
dseid2's Avatar
dseid2
What do you expect, the Mustang is a cheap mass produced car. Can't compare to my 07 BMW 525 in quality, but it is a hell of a lot more fun to drive, clunks and all.
Old May 7, 2007 | 04:17 AM
wolfey2k's Avatar
wolfey2k
Iget what you're saying dseid2. But remember, Ford says or used to say "Quality Is Job One"
If you drive a convertable you'll be in for a nice quiet ride with regards to the front suspension.
No reason the coupe's can't be just as nice! They are now coming out that way too. Since April Ford has added the missing cross member and upgraded the strut assemblies including the strut mounts.
Wolfey2
Pea Ess, I don't settle for rattles and clunks! You should't settle for any less either!
I mean cheapo civics don't make that noise nor do other Ford cars with struts.
No excuse for the Mustang doing it, none at all!
Old May 8, 2007 | 06:52 AM
dseid2's Avatar
dseid2
wolfey2k:
I am planning on adding the BMR A-Arm support in the next couple of weeks, but for performance, notthe fornt suspension clunks. Note that I haveinstalled theEibach Pro Kit,FRPP dampers, Steeda billet strut tower brace, Steeda Front & rear sway bars, Steeda LCA's, Steeda panhard rod and brace and so far no improvement in the clunks, front or rear. Everything was professionally installed. After I install the A-Arm support I will post the results on this forum.
Old May 8, 2007 | 01:42 PM
wolfey2k's Avatar
wolfey2k
ORIGINAL: dseid2
wolfey2k:
Okay, sounds like it's time for you to move over to this thread.
https://mustangforums.com/m_2297319/...tm.htm#3188401
What you're doing is related to what many others have done and or tried in order to correct the cause of the thunking.
Good luck!
Wolfey2k
Old May 11, 2007 | 05:24 PM
Cary Ford's Avatar
Cary Ford
If you had 2K (excluding labor) to mod your GT suspension, while perhaps also addressing the clunking, what would you do?
Old May 12, 2007 | 01:42 AM
RodeoFlyer's Avatar
RodeoFlyer
that recall link is for cars with EIBACH struts, about 400 units.
Old May 15, 2007 | 11:59 PM
owero01's Avatar
owero01
No clunking problems here.
bjdutch2005
Mar 24, 2017 03:38 AM
Gene K
Oct 21, 2015 11:37 PM
robjh22
Suspension
Sep 8, 2015 12:47 PM
Sep 1, 2015 08:16 PM
