Adjustable Panhard bar install
Old Jun 2, 2007 | 12:57 PM
probinator's Avatar
probinator
Default RE: Adjustable Panhard bar install
are the torque specs listed correct 129lbs? I keep thinking 50lbs
Or im I thinking 50lbs for the lca?
Old Jun 2, 2007 | 01:48 PM
howarmat's Avatar
howarmat
s197 Junkie
I couldnt hardly get a torq wrench in there for the panhard nuts but i did tighten them quite a bit. I also put locktite on the jamb nuts to keep them from backing off. I have been told especially with the panhard that 129 might be to much and can eat the bushing. So i think I am fine where I am at.
Old Jun 3, 2007 | 04:48 PM
hotairgypsy's Avatar
hotairgypsy
that link on top was great to know how to install and adjust....I need to find one just like it for the adjustable LCAs but that is for another topic
Old Jun 3, 2007 | 10:57 PM
howarmat's Avatar
howarmat
s197 Junkie
http://www.stangnet.com/Tech-Article...ll-070323.html
You can follow this...it helps some
Old Jun 4, 2007 | 08:55 PM
F1Fan's Avatar
F1Fan
ORIGINAL: howarmat
Whoever told you that was an idot. The Ford shop manual specifications say 129ft/lb. torque for a reason. While you are at it you shouild probably replace those bolts if you have had them off more than once because they are a stretch bolt design as are almostALL of the S197 chassis bolts and fastenersand are stretched at the time of installation and will likely not achive specifed torque but continute to stretch until they yield.
Cheers!
Old Jun 4, 2007 | 08:58 PM
F1Fan's Avatar
F1Fan
ORIGINAL: probinator
129ft/lbs. using only NEW Ford sourced fasteners!
Cheers!
RWHEELS
Sep 5, 2015 03:42 PM
Luke9222
Sep 4, 2015 06:46 AM
Sep 1, 2015 08:16 PM
