Spings installed upside down?
Old Jul 4, 2007 | 03:29 AM
probinator's Avatar
probinator
Default Spings installed upside down?
Hey while I was under my car I noticed that on my springs the eibach lettering or sticker is upside down. A buddy at he dealer did the spring install, So I asummed he did it right? could it be possible to install the rears upside down?
Old Jul 4, 2007 | 12:22 PM
FlaPony's Avatar
FlaPony
Default RE: Spings installed upside down?
He did it wrong...the lettering should be right side up as per the instructions. Contact the Eibach tech line and talk to them, they can e-mail you the instuctions. I imagine the spring rate would be different if they were installed upside down.
Old Jul 4, 2007 | 04:42 PM
v8pilot's Avatar
v8pilot
put it this way, the fatter part of the spring should be at the bottom
Old Jul 4, 2007 | 08:08 PM
probinator's Avatar
probinator
ill have to go and look again. but is it possible to install them back wards. I know there rears are easy to change. is there a write up o how to do it.?
Old Jul 7, 2007 | 05:00 PM
steelcomp's Avatar
steelcomp
With the rears it really dosen't matter...the spring dosen't know if it's right side up, or upside down...as long as the spring is symmetrical in it's mounting, which it is. The progressive part works either way, and being upside down or even sideways isn't going to change the rate. The fronts can't be mounted upside down, so I wouldn't worry about that.
Old Jul 8, 2007 | 05:06 PM
probinator's Avatar
probinator
thank you sir.
Old Jul 11, 2007 | 02:44 PM
TwotoneVert's Avatar
TwotoneVert
ORIGINAL: v8pilot
Not wanting to start an argument, but the Eibachs on my car are right side up, and the fat part is on top. They should be installed witht he pigtail to the outside of the car as well. Unless the newer stangs are different.
Old Jul 26, 2007 | 03:52 AM
mygt500's Avatar
mygt500
Multi-Tasking Moderator!
I think with our cars it is different and Tacobill has a thread on installation of springs....here is a link https://mustangforums.com/m_3070963/tm.htm and I quote "Note: Tight wound coil going up into the body, loose wound coil toward axle. Steeda directions does not address spring orientation. I called Steeda Tech Support to validate correct position. Also, there's no mention on which way to orientate the coil pigtail ends, I just positioned the Steeda coil ends where the OEM ones were" I am sure it is this way for any of the rear springs. The fronts are different as stated earlier. Hope this helps J
mtgldr
Feb 3, 2024 09:00 PM
BOBCATJACK
Sep 14, 2015 02:18 AM
Sep 10, 2015 08:39 PM
